HS5645 Digital vs. HS645MG
What advantages is one going to see by using a digital servo such as the HS5645 over a standard HS645MG?
Both are rated at 6.0VDC: 133 oz-in. and both have the same speed only the digital is $54 while the other is $40.
I am looking for servos for my DP Extra 330L and before I spend the money on digitals I want to know just what benifits I am going to get with them over the others with the same torque, speed, etc...
Thanks... Terry Holland of Golden State RC sent me this link which is a great explanation of digital servos...
http://www.futaba-rc.com/servos/digitalservos.pdf
I'm actually
I'm actually putting the 5945's on elevators and ailerons, and a futaba 9252 on rudder.
Same airplane
6 volt dual battery system with 1700 mah batts all around...Not sure whether I'll use a regulator, but I probably will....
Same airplane
FL
Re: More Battery Drain? nope
Originally posted by RORO
Is it true that if you use all digitals that you have more juices going to them and you should charge more often and use a bigger maH pack??
I'm not talking a little difference either - it's like half the current of other servos. Check for yourself. That means you put in the Hitec digital in place of a std analog servo and get more torque in reserve, and less power used overall. Amazing.
Mike, anything you can add to this?
My Feedback: (19)
TO MIKE MAYBERRY
Why are you saying not to use a 6v regulator on the battery to Rx line. Why would a servo care if it's source was regulated as long as it was working properly.Could you give us some more info please.
The regulators bottleneck the current available and the servo can be starved for power. Plus the Hitec servos can handle up to 7.2V with no problems. Not that I'm suggesting you use a 6 cell battery!
Mike.
Mike.
Mike.
Mike.
My configuration:
8-channel supreme
(4) HS-5625s ( (2) airlon (2) elevator )
(1) HS-5645 (rudder)
(1) HS-425 (or HS-422) (throttle)
(2) MPI Switches
(2) 6Volt 1300mah batteries
H-9 1/4-scale Cap 232
