New Futaba 9C pics anyone ?
My Feedback: (12)
MO
http://www.futaba-rc.com/radios/futj85.html Here is the site what shows all that you ask.
WA
Here you go, unfortunately this is before the bug is fixed, I'll have it sent in and request the taller knobs, and rubber grips with a 9Z handle if possible...
WA
Well, they're certainly taller, but I miss the white stripe on the knob and the "bumps" on top. Maybe they're better because of the ridge along the side.
You can tell you have the error by opeing up a blank model in power plane mode. Take the V-tail mix off inhibit and look at the servo display. Move the right stick around and you'll see channel 1 move, as well as 2 and 4. Right away you'll know it's not v-tail mixing. I'd figure futaba could've gotten this right the first time. Must have been a change in who works the transmitter lab... :stupid:
Finally, we get some pics. Many thanks to rcflier !
BTW, the knobs are not on the Tx. Did you remove them ? I guess that if I were to buy those new knobs, I'll have to change them myself. So rcflier, how did you do it ? Thanks again...........
IL
Raj,
It is a photo i posted at request of others interested.
Esail -- there is nothing wrong in the power plane glider programming -- not sure what you saw or heard, but that is mistaken. The power plane programming is 100% fine without a glitch anywhere.
the only "glitch" is in glider programming with vtail on AND butterfly on AND elevator compensation in butterfly. if u dont use that combination, you'll never see or care if your radio has the error.
