Hitec Flash 5 flaperon setup
Reply
Old 12-05-2004, 08:37 PM
ravencsr
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Hitec Flash 5 flaperon setup
Could anyone shed some light on how to set this up with this radio?? I've read through the instructions and could not seem to find any info on this.
I am using a hitec 555 receiver. I have two servos running the ailerons and another for elevator. Currently I have the ailerons hooked up to a Y cable (I've read somewhere on another post that this is not the way to do it?) into the aileron slot on the receiver.
Do you place each individual aileron servo in its own dedicated slot? Is there anything else that needs to be done?
Thanks for any replies.
ravencsr is offline
Old 12-05-2004, 09:31 PM
carrellh
carrellh's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Hitec Flash 5 flaperon setup
Is it a Flash 5 or a Flash 5X? If it's the original Flash 5 it will not do flaperons and ailerons on a y harness is correct. I'm guessing this is the case since you cannot find it in the manual.
If it's the 5X, you can do it. It is in the manual. One aileron uses channel 1 and the other uses channel 5. Your Y harness will be needed to connect the power supply to the 555 receiver; doesn't matter which slot. You enable flaperons in the ACRO menu.
carrellh is offline
Old 12-05-2004, 11:02 PM
ravencsr
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: carrellh
Why is it that you would have to plug the power supply into the Y harness? would it not just stay in its dedicated slot (Channel 3)?
ravencsr is offline
Old 12-05-2004, 11:17 PM
carrellh
carrellh's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I thought the 555 had only 5 slots for connectors.
That's all the photo at http://www.hitecrcd.com/Receivers/micro555.htm shows.
1 Aileron
2 Elevator
3 Throttle
4 Rudder
5 Aileron
You have to get battery power to it from somewhere.
The photo indicates ch 5 is the 'normal' place to attach the battery power.
carrellh is offline
Old 12-05-2004, 11:31 PM
ravencsr
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sorry Carrell, forgot to mention [:'(], this is for an electric plane, therefore I'm using main batt which uses channel three from ESC as pwr supply to receiver.
ravencsr is offline
