TX Crystal in a Receiver
My Feedback: (51)
FL
RE: TX Crystal in a Receiver
Ok i thought the answer was yes, after all a crystal si a crystal what is the difference from a tx one and a Rx one technicaly speaking?
CA
There are many differences. For one, the Rx xtal will be at least 455Khz away from the Tx freq (and as much as 11Mhz different). Other differences include, but are not limited to, the overtone mode used, capacitance, and pullability.
RC-CAM
RC-CAM
My Feedback: (29)
IA
Well, we used to do that about 20 years ago.........when I was racing RC cars...........on 27.........AM. Occasionally we might run into a freq. conflict, and one of the competitors would announce he would use his "secret" freq.[X(][X(] Everyone turned there heads so they did not see and the racer would change his Xstals. It seemed to work then. I guess things are different now
Ron
Ron
My Feedback: (29)
IA
ORIGINAL: norbe
If I don't recall wrong there is a place that exchanges the crystals what was it?
Ron
My Feedback: (29)
IA
ORIGINAL: piper_chuck
The racer probably had a pair (tx and rx), and changed both. After all, it would do no good to just swap one of the two crystals.
[sm=confused.gif][sm=confused.gif][sm=confused.gif]
Ron
AZ
It could work today if you are using a single conversion receiver. Only one problem: Its illegal- as it was on the 27MHZ systems. With a double conversion receiver the crystals are too far off frequency for the system tuning to work.
Dirtybird, I doubt if it would work today even with single conversion as the transmitter crystals are usually approximately 1/3 the frequency of the final frequency (the transmitter operates on third overtone) while the receiver circuitry does not.
My Feedback: (51)
FL
One thing I don't understand is how and why, technicaly, does the trasmitter have a third of offset. Shouldn't it be at the same frequency? Wouldn't it be better?
AZ
ORIGINAL: Rodney
most recievers are dual conversion type which means that the first xtal is 10.7mhz away from transmitter freq. the next conversion converts signal to 455kc. the reciever xtal is 455kc away fron the transmitter freq. therefore they are not interchangeable.
Dirtybird, you are correct on most of them using 5th overtone, I am not sure what the receivers use but probably similar due to the frequencies involved.
