how to replace a broken gimbal (pics)
Reply
Old 12-30-2004, 01:31 AM
Sokhar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default how to replace a broken gimbal (pics)
hey guys I got a Futaba t6xa and one of the sticks is broken but I wanted ot fix it to use in AFPD I took it all apart but cant seem to be able to get the connector to release fromt he printed circut boards maybe you can tell me what I am doing wrong
its the ST-R and ST-L connectors
Pics *******warning Hi RES 2mb each********
http://www.fbiclan.us/Radio1.jpg
http://www.fbiclan.us/Radio2.jpg
http://www.fbiclan.us/Radio3.jpg
Sokhar is offline
Old 12-30-2004, 02:12 AM
sfsjkid
sfsjkid's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: how to replace a broken gimbal (pics)
Sokhar,
Hate to say this but those "connectors" aren't designed to come apart. They are designed to facilitate the assembly process, and soldered onto the board.
Good Luck!
sfsjkid is offline
Old 12-30-2004, 04:18 PM
Lynx
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Considering you'll probably melt the 'connector' in the process of desoldering, just cut the entire thing off about an inch above the board and solder the wires from the new gimbal on.
Lynx is offline
Old 02-18-2005, 10:47 AM
Brokenprop
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
While we have the back off of that transmitter, can anyone tell me where the antenna wire is connected. I can't get sokhar's pictures to download. The flimsy bracket holding the antenna in the case broke on mine. I can repair the bracket, but haven't a clue where the wire goes. It appears to have pulled from a connector (clean wires with insulation removed), but I don't see one. On an older Futaba they did use a connector.
I used to build this stuff when it had vacuum tubes and discrete components. In this one I have found the RF board, but I'm not sure where the output is. There doesn't seem to be discrete a final amp.
Brokenprop is offline
