Airtronics Vision 8P how to set up flaperon
MI
Hello,
I lost my Vision manual, and I am trying to program the radio so the 2 ailerons can move up or down together to act as flaps. I use separate channel for the 2 aileron inputs, using configuration 2A 1R 2E 1T I navigated through the functions I see, and I didn't find any that works yet. Help, anyone? Thanks!
MI
Hello,
Thanks for your advice. Right now I have 2 elevator servos that are mounted in the opposite direction that I will need 2 elevator channels and reverse one of them. However, I found a cheater's method: using "virtual flaps" to mix elevator channel and the 2 ailerons as flaperons.
1) use C-mix (master-slave) to mix elevator channel to the non-existent flap channel.
2) use B-mix 1 (bi-direction mix) to mix flap to left aileron and B-mix 2 to mix flap to right aileron.
3) assign a switch to control flaps channel, which is mixed to the 2 ailerons
3) assign another switch to turn on and off the C-mix between elevator and flap channel
