PCM9X Range
Reply
Old 01-04-2005, 06:57 PM
min
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default PCM9X Range
Hi
I would like to know what is the distance btween the PCM9 TX and a PCM RX with the antenna retarcted?
I tested 50 steps there was no signal, once the antenna got extended it was fine.
Is there any KNOWN ways to test the range? ( range check procedure )
Thanks 'n' Regards
min is offline
Old 01-04-2005, 07:45 PM
Technito20
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: PCM9X Range
With antenna down you should get at least 100 feet without any interference whatsoever. Even though it's PCM, the transmitter still only puts out a 1/4 watt of power therefore rated at about a mile range with the antenna fully extended. PCM is the same as FM except PCM eliminates all foreign radiowaves between Tx and Rx making it glitch free. The only time it will glitch if someone is directly on your channel.
Technito20 is offline
Old 01-04-2005, 08:30 PM
smokingcrater
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
read the large # of recent threads, pcm and fm are not interchangble, i think you probably meant PPM...
smokingcrater is offline
Old 01-05-2005, 07:45 PM
Mac_Man_UK
Mac_Man_UK's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
http://www.macgregor.co.uk/faq/Care/Range%20Tests.pdf
[8D]
Mac_Man_UK is offline
