9C and flapperons, need a little help..
TN
Have a Hobby Lobby Grumbler and my 9C. I never programed in this plane until tonight. I went to the Futaba's websight, where I had bookmarked the setup for flaperons, and how to set it up. I am close though..
Ailerons on 1-6. They move like they should. I just cant get them to go down, I can mess around, and get it close, but the C switch makes them go to airbrakes, then, to flaps with little aileron control. I want switch C up to be neutral, middle selection on C to be slight down, and down C to be lowest setting on flapperons. How can I do this. I am out of town and going to a fly in....and forgot my manual that always goes with me ! Man, I am bummed. Thanks... Keith
TN
RE: 9C and flapperons, need a little help..
Sounds like it will only go down as far as it goes up. Sounds also like youcant program it to do 2 steps down, as in a real plane, 2 stage flaps.. Thats a bummer for such a nice radio like the 9C.... Weird...
AR
It is not that difficult, you have to set up a mix for each servo and also for each position, ie set up channel on on a mix to move a little bit, then assign it to switch c middle, then do it again with more throw and assign it to switch c down then repeat for channel 6. this should work but is a little cumberson ro program.
Terry
Terry
TN
I am a little bit lost, I have fresh batteries and hours more to try. Thanks for your input, I know it isnt hard, its just a little confusing. Thanks.,
