9c helo programming
Reply
Old 02-01-2005, 08:29 PM
a65l
My Feedback: (17)
a65l's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default 9c helo programming
OK, I'm on my first helicopter. I've got some experience programming airplanes, but I went in to do some dual rates on the helo programming, and I'm confused. In the d/r,expo menu I've got:
[D/R,EXP]
CH>1234 (ALIE)
No>UPv (UPv)
D/R>
EXP> 0%
SW>D
OK, I understand how to change switch assignments, and how to actually program in the expo. In teh aircraft menu, as you change the switch on the radio, the third line changes to UP or DN depending on switch position, as it does in teh helo menu. However, in teh aircraft menu, the dual rates display and exp display change when you change the switch position. They don't here. However, when you move the cursor up to the No> and change than from UP to DN, they do change. But the switch dosen't change that setting... only the cursor and the wheel. So....??????? how do I set up expo?
Thanks in advance,
Andy
a65l is offline
