Optic 6 or Futaba 7C?
RE: Optic 6 or Futaba 7C?
Hi,
If you have any need for Aileron Differtial function (which allows 2 aileron servos with the 2nd one on channel 5) I would avoid the Optic 6 for now. There is a fatal firmware bug which can cause total lockup of the Tx, in flight, under certain combinations of throttle trim, sub-trim & throttle stick position! There is supposed to be a fix in progress but I'm not expecting it soon.
CFIMEI
CFIMEI
MD
ORIGINAL: COOLAIR
Looking to purchase new radio to fly mainly 3D planes. Looking at Optic 6 and 7C. Any comments or help with the decision?
Coolair
Coolair
-Kwok
Consider this also: The CROW feature in the Optic 6 does not allow aileron trim to be applied to both ailerons unless the fatally flawed ADIF feature is also enabled. I wouldn't use this Tx with any airplane over 10 oz. AUW without having my lawyer look over the fine print in my AMA insurance!!
CFIMEI
CFIMEI
I love my Optic 6 and use CROW and Ail dif all the time including in my big birds. If you need -60% throttle trim which is what causes the lock up then your set up is way off anyway. I've never had a problem and from what I've heard only one person ever has. Sure it's there, but chances are it will never ever affect you since you know what causes it.
I also have the E7 but like the Optic better for its versitility. Including the Ail diff with 5 channel RX's... I have a ton of 555's!
Maniac.
Maniac.
