Be Aware!!!
Reply
Old 02-08-2005, 08:38 PM
sputknik
sputknik's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Be Aware!!!
Do not clean your potentiometers with any type of cleaning fluid.There are 4 potentiometers connected to each control stick.You have to use extreme care when using contact cleaner to clean up an intermittent pot.The solvent will cause the plastic to split or snap.Apparently it causes a chemical reaction with abs based plastics.Thats what most radios are made from.Just my personal experience.I tested a piece of radio plastic with some solvent"electronic cleaner" and the plastic just disentrigrated.
sputknik is offline
Old 02-08-2005, 10:20 PM
Flyboy Rich
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Be Aware!!!
In the past with the older servos I used rubbing alcohol to cler the pots. Never needed to clean a tx
Flyboy Rich is offline
