Futaba servo & receiver current drain
My Feedback: (16)
GA
FOr the receiver you should be able to get that from Futaba's website or Tower Hobbies. I think it is 10ma. FOr the servos, you probably will not get any data unless you look for Max current. Idle current will not be listed.
www.futabarc.com
www.futabarc.com
My Feedback: (16)
GA
Futaba R127DF FM 72MHz Low w/o Crystal
Current Drain: 10mA
Futaba R148DP PCM 72MHz Low w/o Crystal
Current Drain: 14mA
Futaba R149DP PCM 72MHz Low w/o Crystal
Current Drain: 15mA
As I said before, servo data is usually not available
Current Drain: 10mA
Current Drain: 14mA
Current Drain: 15mA
