Retract Servo power set up....
FL
A little back ground first. I installed retracts into my Ultra Sport and I need additional tail weight so I am putting the retract servo on it's own 270Mah Battery so that added weight will not be just lead but will be working for me.
I took the Servo connector apart so that the only wire left on the Servo connector is the Signal wire. I took both the Positive and Negative wires off the retract connector and put them on their own female connector and pluged that into the 270mah battery.
I have the signal wire plugged into the Rx and the + and - wires into the spare battery. The Retracts worked before I started and aren't working now with my new set up.
Does the servo need more than just the signal wire going to the Rx to work? Maybe the - wire too.
What am I doing wrong? I don't want the retract servo to lock up and drain the main flight pack and lock up my flight servoes and do the plane in so since I need the additional weight I am trying this set up to add some insurance to my plane.
I hope this is enough info....ask questions if you need more info...Thanks in advance for your help. [&o]
FL
RE: Retract Servo power set up....
Thanks Les. I'll give that a try and see how that works. I'll splice a wire in off the battery line and see how that works.
FL
Thanks Les! It works like a champ!!!! So now I have useable balast and a sence of security with the additional battery on the retracts.
