f.M. or P.C.M. ?
f.M. or P.C.M. ?
We are have an ongoing debate in our r/c club about the pros and cons of pcm vrs fm with gas engines. can someone please give me some input?
f.M. or P.C.M. ?
This subject gets repeatedly discussed here and at times becomes redundant. Please see this thread
http://www.rcuniverse.com/showthread...803&forumid=27
Also use the search feature and you will find lots of info.
Mikee
Mikee
VA
f.M. or P.C.M. ?
looks to me like chester needs to be using PCM on his gas planes. Something not mentioned here is that you will get little more distance during a range check with the antenna down using PCM.
In my experience PCM gives me about 35% more range vs PPM during range checking..
Good Flying
Terry
Good Flying
Terry
