hs-55
TN
hs-55
Hey guys i just finished my FunPlanes.com edge 540 w/ axi 2212/34. TP 1320mAp battery Eflite 20 amp esc and 4 hs55 servos.
My question is are the hs55 servos good ( will they do the trick)
My Feedback: (8)
RE: hs-55
I've used HS-55's on several 3D planes up to 20oz AUW with brushless set ups that provided at or over 2 to 1 power to weight... never a problem with the servos other than a hard hit that stripped gears... certainly not the servos fault
John
John
