Futaba 3152 Servo....any info?
GA
Just curious if anyone is using the 3152 Futaba digital servo??
http://www2.towerhobbies.com/cgi-bin...?&I=LXHKB0&P=7
They are right in the range for torque and speed I am looking for and the price is good.... but searches brought up almost nothing..
the specs for them say they are for cars or boats...is there a reason to not use thm in planes??
they are in ths same range for size and weight of other servos....
any thoughts??
any thoughts??
My Feedback: (13)
RE: Futaba 3152 Servo....any info?
These servos are still relatively new; not many folks have them yet. There are a dozen or so 3151s at my field. At first, I thought that the idea of an inexpensive digital sport servo was a splendid one. But these servos, in use for a few months, are already slowing signs of slop.
This is far too small of a cross-section to draw any conclusions from; but it is enough to give me pause. I have four 3151s that I'm going to put in a Sig Kougar, fly them for a while, and see how they do before I buy any more.
To address your specific question, no, there is no particular reason not to use a designated "car servo" in an aircraft. The JR 4735 analog is a purpose-specific high-end car steering serevo that just happens to work admirably as a helicopter servo, and, in fact, was one of the tail rotor servos of choice prior to the advent of digitals.
What I'm curious about is this: going by the specs, the only difference between the 3151 and 3152 is that the latter is a hundreth of a second slower and somewhat stronger (torque output wise); yet it is two bucks cheaper. My guess is that what we're seeing here is similar to the 3001/3004 situation.
While both are "standard" ball-bearing servos, the 3001 is really just a S148 with a bearing. The S148 has been Futaba's bread'n'butter servo for many, many years. The 3004 is a follow-on, made to sell for less (or more profit margin, depending upon your point of view). The REAL difference is that the 3004 has a less-sophisticated feedback potentiometer, and will fail under high vibration levels; such as exist in model helicopters.
If that is the case, then I would not hesitate to use the 3152 in a fixed wing airplane. But it could be something like a cheaper motor, etc.
Perhaps Bax will see this and chime in. He's the service guru (I think), and would probably know if anyone does.
GA
Excellent info.....thanks....I didn't realize they were that new....
it is for the Ailerons of a .60-.90 size plane so I don't need huge torque but I really like digital now that I have flown with them...
I was looking at the Hitec 5475 as well
Cheers
Cheers
Banned
Given a choice between the Futaba 3151 and Hitec 5475 I'd go for the Hitec every time.
I'm using the 5475s on several planes and they are great -- although they really do need a 5-cell pack to give (what I would call) acceptable speed -- but then again, I mainly fly 3D.
Other fliers at our club are using the Futaba 3151 servos and most of them are getting quite sloppy after just a few months' use. It appears as if there's a lot of radial lay in the output shaft. By comparison, my Hitecs are as tight now as the day I installed them and some have more than 40 hours hard flying on them.
The real difference is that the S3151 servos sell for just $19.95 (ServoCity's two-for-one deal) whereas the Hitecs are nearly twice the price at $35.
Rather than also use these cheap Futaba digitals, I'm using non-digital HS475 ones ($17) on most of my sport planes. They're possibly not as precise (although I can't see any difference) but they have lots more torque and won't wear out any time soon.
