JR XP347 Problems
OK
JR XP347 Problems
I have an older JRXP347 7 Channel 4 model memory radio. My problem is that on one of the models, (Telemaster) all of the channels work fine except for the ailerons.We have checked the wiring, checked the wing servos and everything is apparently OK. (All functions work fine on the other three models).. I copied the settings from one of the other models to the Telemaster settings, but no luck. Could there be some internal problem with the transmitter that would hinder the Telemaster aileron function? We're close to throwing in the towel. Thanks.
VA
RE: JR XP347 Problems
Couldn't tell from your post what the problem was...
Are you using seperate servos in the wing? Sounds like you are.
If so...are you using the Flaperon function?
I had a similar problem with my JR XP8103... I had a used a set up from another plane and when I tried to use it for my Telemaster the ailerons did not function opposite as they should - they moved together in the same direction...
"Reversing" the Aux 1 or the Aileron servo in the FLaperon mode fixed it.
Now it does fine.
Now it does fine.
