JR X2610 programing question
hi, im running duel servos on the elevator of my edge 540 and was wondering if it is possible to program the serovs so that the both elevator halves are in 0 up/down position, and so that they have even amounts of travel. or does this need to be done manualy?
thanks.
thanks.
RE: JR X2610 programing question
Hey nice picture of the pig pump 'n' dump, any how... just baught one (X2610) myself and I reckon that the best way for you to do this is to use one of the free mixes, and mix elev to elev. You can do this, the manual even suggests it, Im almost certain I've read it. Then, (This is the part I like best!) instead of assigning it to a switch which could otherwise be used for something that you want on/off control over, you can select 'always on', or 'inhibit' (I think thats what its called). You can then selectively alter either servo. Hope this has helped! Just incase I've led you on a goose chase and it turns out my advice is wrong, Im sorry.
