5 ch single stick?
5 ch single stick?
Back in the day, I had a 5 ch single stick tx (Kraft, I think). I'm returning to the sport after a 25 year absence but I have a disability that makes holding/using a dual stick tx tough. Is anyone manufacturing a 5 ch FM single stick tx?
Thanks-
John
Thanks-
John
single stick
If you have your old Kraft or get a Single Stick thru Ebay you can send the TX to KMI to be updated. Try to keep it to a 1977 or later. I would buy a new airbone setup.
Also, Hitec has a new single stick to replace the Focus. The new radio is a NEON and will have 4 channels, dual rates and atv. It is in the current 2003 Tower catalogue.
single stick
welcome back toy
I'm just back as well after a 22 year layoff. I also returned with a disability. After several try's I finally tried a TX tray, and it really made the diff. I don't know what type of problem you have but, with me , a wreck left me in a wheelchair and 20% use of my a
rm's and hands . Buz^
P.S. I now have 22 flight's in and have built (no ARF's ) 5 plane's , good luck and happy flying
5 ch single stick?
Multiplex have all sorts of do-das you can add to the sticks, flick switches on top, and i believe a rotary bit near the top for throttle
5 ch single stick?
Thanks guys. Don't have the old Kraft anymore- kinda wish I'd kept the old stuff ... like the tube rx, 10 ch reed setup (remember MinX servos, McCoy engines and the Tarus and Orion pattern ships?) ah, but I date myself. I'll check out the Hitec and ebay.
Thanks again,
John
Thanks again,
John
