Help on servo torque specs PLEASE
WY
Hello out there.
I have the following servos and would like to know the torque values. These were from old airplanes and I can't find the torque values anywhere.
Thanks for the help
FPS30
FPS38
FPS28
Thanks for the help
FPS30
FPS38
FPS28
My Feedback: (31)
RE: Help on servo torque specs PLEASE
Thems OLD Servos......
Servo # - Length x Width x Height-in. - Connector Type - Weight oz. - Torque oz.-in. - Speed - Replacement #
S6 1.54 x 0.71 x 1.48 G 1.37 27.80 S148
S7/107 1.73 x 0.91 x 1.61 G 1.68 41.70 S3003
S7L 1.73 x 0.91 x 1.61 G 1.68 41.70 N/A
S8G/S108G 1.73 x 0.88 x 1.62 G 1.70 111.10 S136G
S10/110 2.93 x 1.50 x 3.50 G 8.80 122.30 21.8"/3.8 sec S5801
S11 1.75 x 0.75 x 1.50 G 1.40 25.10 N/A N/A
S12 1.90 x 0.91 x 1.41 G 1.80 35.00 S3003
S14/114 2.93 x 1.50 x 2.06 G 8.80 167.00 0.29/60 S3801
S15 1.90 x 0.91 x 1.41 G 2.10 44.50 S3004
S15(M) G 1.90 x 0.91 x 1.41 G 2.10 55.60 S136G
S15(M) L 1.90 x 0.91 x 1.41 G 2.10 44.50 N/A
S16 1.63 x 0.75 x 1.40 G 1.50 27.80 S3002
S16G 1.63 x 0.75 x 1.40 G 1.50 36.10 N/A
S16L 1.63 x 0.75 x 1.40 G 1.50 36.10 N/A
S17 1.56 x 0.78 x 1.57 G 1.60 27.80 S148
S18 1.56 x 0.78 x 1.57 G 1.60 27.80 S148
S20 1.19 x 0.69 x 1.13 G 0.85 22.20 S3101
S20L 1.19 x 0.69 x 1.13 G 0.85 22.20 N/A
S21 1.56 x 0.76 x 1.67 G 1.26 41.20 S9001
S21G 1.56 x 0.76 x 1.67 G 1.26 48.10 S136G
S21S 1.56 x 0.76 x 1.67 G 1.26 50.00 S9001
S22 1.73 x 0.90 x 1.67 G 1.80 32.10 S3003
S23 1.55 x 1.57 x 0.78 G 1.50 27.80 S148
S24 1.80 x 0.88 x 1.50 G 2.10 62.70 0.23/90 S9202
S25 1.75 x 0.88 x 1.69 G 2.30 129.30 0.62/60 S3801
S26 1.56 x 0.75 x 1.56 G 1.70 43.10 S148
S26L 1.56 x 0.75 x 1.56 G 1.70 43.10 N/A
S27 1.75 x 0.87 x 1.69 G 1.90 47.30 S9202
S27L 1.75 x 0.87 x 1.69 G 1.90 47.30 N/A
S28 1.50 x 0.75 x 1.56 G 1.80 48.70 0.24/60 S148
S28L 1.50 x 0.75 x 1.56 G 1.80 48.70 0.24/60 N/A
S29 1.75 x 0.88 x 1.69 G 2.10 48.70 0.25/60 S9101
S29L 1.75 x 0.88 x 1.69 G 2.10 48.70 0.25/60 N/A
S30 1.50 x 0.75 x 1.31 G 1.40 55.60 0.24/60 S9101
S30G 1.50 x 0.75 x 1.31 G 1.40 65.30 0.34/60 S136G
S30L 1.50 x 0.75 x 1.31 G 1.40 55.60 0.24/60 N/A
S31S 1.50 x 0.75 x 1.31 G 1.70 44.50 0.22/60 S9202
S31SH 1.59 x 0.79 x 1.40 G 1.70 44.50 0.16/60 S9401
S31SL 1.50 x 0.75 x 1.31 G 1.70 44.50 0.22/60 N/A
S32 1.43 x 0.68 x 1.18 G 1.10 33.40 0.16/60 S9602
S32H 1.06 x 0.50 x 1.12 G 1.10 25.00 0.13/60 S9101
S33 1.59 x 0.79 x 1.14 G 0.60 27.80 0.22/60 S3101
S33L 1.59 x 0.79 x 1.14 G 0.60 27.80 0.22/60 N/A
S34 2.23 x 1.14 x 1.97 G 2.70 112.60 0.22/60 S3302
S34G 2.23 x 1.14 x 1.97 G 2.80 173.80 0.33/60 N/A
S34L 2.23 x 1.14 x 1.97 G 2.70 112.60 0.22/60 N/A
S35 1.21 x 0.62 x 1.18 G 1.10 36.10 0.17/60 S9602
S35S 1.21 x 0.62 x 1.18 G 1.10 36.10 0.17/60 S9602
S36G 1.75 x 0.87 x 1.00 G 1.48 76.40 0.50/60 S136G
S38 1.59 x 0.77 x 1.58 G 1.50 38.00 0.22/60 S148/S3003
S107 1.73 x 0.91 x 1.61 J 1.68 41.70 S3003
S108G 1.73 x 0.88 x 1.62 J 1.70 111.10 S136G
S110 2.93 x 1.50 x 3.50 J 8.80 122.30 21.8"/3.8 sec S5801
S114 2.93 x 1.50 x 2.06 J 8.80 167.00 0.29/60 S3801
S121 1.56 x 0.76 x 1.67 J 1.26 41.20 S9001
S121G 1.56 x 0.76 x 1.67 J 1.26 48.10 S136G
S125 1.75 x 0.88 x 1.69 J 2.30 129.30 0.62/60 S3801
S125 1.56 x 0.88 x 1.69 J 2.30 129.3 0.62/60
S128 1.50 x 0.75 x 1.56 J 1.80 48.70 0.24/60 S148
S129 1.75 x 0.88 x 1.69 J 2.10 48.70 0.25/60 S9101
S130 1.50 x 0.75 x 1.31 J 1.40 55.60 0.24/60 S9101
S130G 1.50 x 0.75 x 1.31 J 1.40 65.30 0.34/60 S136G
S131S 1.50 x 0.75 x 1.31 J 1.70 44.50 0.22/60 S9202
S131SH 1.59 x 0.79 x 1.40 J 1.70 44.50 0.16/60 S9401
S132 1.43 x 0.68 x 1.18 J 1.10 33.40 0.16/60 S9602
S132H 1.06 x 0.50 x 1.12 J 1.10 25.00 0.13/60 S9101
S133 1.59 x 0.79 x 1.14 J 0.60 27.80 0.22/60 S3101
S134 2.23 x 1.14 x 1.97 J 2.70 112.60 0.22/60 S3302
S134G 2.23 x 1.14 x 1.97 J 2.80 173.80 0.33/60 N/A
S135 1.21 x 0.62 x 1.18 J 1.10 36.10 0.17/60 S9602
S135S 1.21 x 0.62 x 1.18 J 1.10 36.10 0.17/60 S9602
S138 1.59 x 0.77 x 1.58 J 1.50 38.00 0.22/60 S148/S3003
S148 1.59 x 0.78 x 1.42 J 1.50 41.70 0.22/60 S3003
S3104 2.33 x 1.13 x 1.96 J 3.35 128.0 0.21/60
S3106 0.40 x 0.90 x 0.80 J 0.30 16.6 0.11/60
S5101 1.52 x 0.77 x 1.36 J 1.40 55.60 0.24/60 S9001
S5102 1.06 x 0.50 x 1.12 J 0.80 27.80 0.22/60 S3102
S9201 1.59 x 0.79 x 1.40 J 1.70 69.50 0.22/60 S9202
S9203 1.59 x 0.79 x 1.48 J 1.90 76.4 0.11/60
S9204 1.59 x 0.79 x 1.48 J 1.90 131.2 0.19/60
S9205 1.59 x 0.79 x 1.48 J 1.87 76.4 0.11/60
S9250 1.59 x 0.79 x 1.48 J 1.90 76.4 0.11/60
S9301 1.59 x 0.79 x 1.40 J 1.70 69.50 0.22/60 S9202
S9302 1.59 x 0.79 x 1.55 J 2.30 99.00 0.19/60
S9303 1.59 x 0.79 x 1.56 J 2.28 79.80 0.24/60
S9401 1.59 x 0.79 x 1.40 J 1.80 44.00 0.16/60 S9101
S9403 1.59 x 0.79 x 1.40 J 1.75 44.50 S9202
S9404 1.54 x 0.79 x 1.47 J 1.94 63.20 0.14/60
S9450 1.59 x 0.79 x 1.48 J 1.94 111.0 0.09/60
S9601 1.21 x 0.62 x 1.18 J 1.10 36.10 0.17/60 S3002
*G designation always indicates retract servo
*L designation always indicates reversed servo
N/A = Not Applicable
Hi Steve,
You can find all this info on our Futaba website at:
http://www.futaba-rc.com/servos/disc...ed-servos.html
Just go to the website, click on "servos" on the righthand side, once you are there scroll till you see the link for "discontinued servos".
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
Sincerely,
Krysta
