Futaba 9CAP Timer Question
In addition to the S1 and S2 timers there is the main timer that seemingly shows the amount of time on the radio. Is there a purpose to this timer other than the total amount of time on the radio? How is this info beneficial? Can/should it be reset? A friend of mine was flipping through the menus and the main timer began to flash as if it could be reset, but he moved on and nothing in the manual refers to the main timer, just S1 and S2. Any thoughts?
Thanks in advance,
harphunt
Thanks in advance,
harphunt
My Feedback: (47)
AL
RE: Futaba 9CAP Timer Question
I use it to keep up with TX battery time between charges.
Yes, you can reset it without harm.
You can also reset the bottom timer (MDL) which is total time on the particular model you have displayed.
Press the lower right edit key until the timer flashes then press down the dial until it resets.
There are 4 timers. (All can be reset)
Transmitter time.(Timer)
S1
S2
Model Time (MDL)
S1
S2
Model Time (MDL)
My Feedback: (61)
NJ
ORIGINAL: OldCoot
IYou can also reset the bottom timer (MDL) which is total time on the particular model you have displayed.
S1
S2
Model Time (MDL)
S1
S2
Model Time (MDL)
How is the main timer reset? I can't imagine its use is for battery time as the meter would inform one about that. I don't have a model timer either, that I know of.
harphunt
harphunt
My Feedback: (61)
NJ
to reset the main timer
press the up arrow on the right and the time will flash..then hold in the wheel for a second or two and the time will reset to 0
I think the 9C timer is the pits. I also have a 9VAP and an 8UAP and both are much more user friendly than the 9C timer. The 9C instructions are also bad for the timer function.
Dave
Dave
My Feedback: (16)
GA
Y ou have to attempt timer reset just after power up. If you do something else first, it will not work.
While the 9C and 8U's are functionally the same, both radios are a step above the old 8U.
