JR 662 Charger
JR 662 Charger
Somehow I have managed to lose the charger and manual to my JR 622 radio. Does anyone know where I can replace these? I was going to just get a charger at Radio Shack but without the manual I have no idea about the voltage.
Darin Linford
Darin Linford
My Feedback: (13)
RE: JR 662 Charger
You can get a general purpose wall-wart charger, but you will probably have to solder on the right connector. On the JR charger, you are charging a 9.6 V pack (transmitter) so you need an output voltage of about 12 volts and 50 mA. For the receiver you need about 6 volts and also about 50 mA. The JR transmitters are "backwards" of what many connectors use. the center pin is negative and the outer ring is positive.
