Optic 6 question?
My Feedback: (16)
Optic 6 question?
Has any of you guys that own this radio been able to link flaps when deployed with down elevator trim? I can't see anything in the manual about it (it does have down flap with up elevator, to aid in pylon racing tight turns), and also, I haven't been able to set the flaps throw without affecting the neutral or off position, is this the only way to set the throw thus having to adjust the neutral position at the servo wheel and/or pushrod linkage?
One other thing that I don't understand is why the right lever on the side of the transmiter also moves the flaps, although just a small amount?
Any replies will be greatly appreciated.
Another question:
When using channel 5 for for aileron differential, can the channel 5 on the receiver be used with a Y connector in order to power up the retracts, or is this designation lost due to the aileron differential feature?
Another question:
