Problem setting up my 9X!!
I tried to set up the ailerons on my seagull edge tonight. I came across a strange problem. The servo's don't move and even amount up as compared to down. I have them set up as flaperons so I thought ah ha I have the aileron differential on. I checked that and it is definitely inhibited in high and low rates. I even turned it on and moved them to + and - 100%. The servo's did not move any different.
I am using DS811's on a 6V pack. I am at a loss. Any idea's as to whats going on here?
RE: Problem setting up my 9X!!
Problem sorted. Turns out for whatever reason the flaps were set to 100% up so when I centered the ailerons they were running out of travel in one direction.
