JR Radio buddied up with a GWS ?? Can it be done ??
My wife bought a GWS Slow Stick and A GWS Radio to fly, ... I have been trying to use my JR6102 to train her with but cant get the dang thing to work !!! grrrrrrrr.... Does anybody out there know if this will even work ? I would be glad to get some help or at least know if I should just purchase another radio for training purposes.. this whole thing is making me crazy !!
Thanks Guys..
Thanks Guys..
RE: JR Radio buddied up with a GWS ?? Can it be done ??
Hi,
Questions :
1) Is the GWS-transmitter fitted with a buddy-box connector? According to your sayings, I suppose it is.
2) If question 1 is positive, what type of connector is it? I assume you use a JR buddy lead, which consists of 2 male jack (3.5mm or 1/8" ) MONO. But according to this website, the GWS described there is a STEREO jack with other connections : http://homepages.paradise.net.nz/bhabbott/fms.html
So check inside the GWS-transmitter if yes or no it's a STEREO jack. If YES, then you will need to make a new buddy lead with one mono jack and one stereo jack : the mon jack to be fitted in your JR, the stereo into the GWS.
To make the new buddy-lead, connect the "OUT-signal" (ring) of the STEREO-connector to the tip of the mono plug. The GROUND (sleeve) of the stereo connector should be connected to the sleeve of the mono-plug (this all according to the website I found).
Of course, you could check by yourself if the OUT-signal is really there as per that website, by using a free downloadable scope (URL and how to use to be found on my website chapter 1, paragraph 1.1., see my webaddres below signature).
If this cable-setup does not work, you could switch signal-OUT with GROUND and test again, but then be sure never allow metal parts of one transmitter touch metal parts of other transmitter.
3) If question 1 is negative, did you check here :
http://www.rcgroups.com/forums/showt...ws+transmitter
and here :
http://www.rcgroups.com/forums/showt...hreadid=175110
Both transmitters probably to be switched on if GWS does not switch on automatically when pluggin-in the buddy-lead. And for safety, ALWAYS remove crystal of slave transmitter! The slave transmitter does not need to transmit!
And of course master-transmtiter to be on the same frequency as the receiver in the model you want to learn with.
With the JR6102 you could use the "pilot-link master function", check-out here :
http://www.rcuniverse.com/forum/JR_6...2222884/tm.htm
Keep in touch, interesting item for others to know any effective solution !
Olivier
Questions :
and here :
Olivier
