Futaba Servos and Receiver and JR Radio
AR
If I used futaba servos on a Futaba receiver on channel 37 and I had a JR XP6102 Transmitter also on channel 37 would the servos act as JR servos, basically my question is can I use Futaba equipment on JR radios just fine and have no problems because I wanna get the Great Planes Flatout Turmoil and the only good inexpensive flight equipment is Futaba and I already have a brand new radio which is my JR radio and I see no problem just as long as they are on the same frequency but I want to make sure it would work before I buy a new set of servos and reciever.
-Wes
-Wes
AR
RE: Futaba Servos and Receiver and JR Radio
so you are saying the futaba servos would work but i have to modify them to fit in a jr receiver and it would work great
Bill
Banned
IN
You can use about any servo with about any RX. You don't even have to worry about damaging the RX or servo if you plug them in backwards, since the power is always on the middle pin. However, on Futaba, the connector has a little tab to ensure they are plugged in correctly. To use a Futaba servo with another brand of RX, you'll have to shave of the little tab.
Regards,
[8D]Suzie
Regards,
[8D]Suzie
My Feedback: (19)
To use a Futaba servo with another brand of TX, you'll have to shave of the little tab.
I bet dominator73439 would like to have a TX that had the ability to select shift.
Banned
IN
I know that everything has to be perfectly spelled out for you. I'll try harder next time not to make any mistakes, because I always feel sorry for the short-bus graduates.
Suzie
Suzie
AR
thanks, yea that would be great if i could switch shifts it would be alot easier, thanks for all your help
