Servo Futtering ??? Radio or Battery????
Old 10-14-2002, 05:10 PM
JAkridge
Default Servo Futtering ??? Radio or Battery????
Airleron Servo fluttering at power up.
Useing JR equipment, 1100 mah rx pack, R600rx. 652tx and 537 servos. All equipment is very New.
AM I HAVEING A RECEIVER-TRANSMITTER PROBLEM, SERVO PROBLEM OR A POSSIBLE BATTERY MELT DOWN. THE BATTERY IS SHOWING SIGNS OF NOT GETTING FULLY CHARGED. BUT WITHIN LIMITS..
Any help ...
Old 10-14-2002, 08:32 PM
Rodney
Do you really mean fluttering or just jittering while sitting with no airloads on the system? Sounds like you mean the latter. If so, do you have your transmitter on when this happens or just the receiver? You need to clarify your problem.
Old 10-14-2002, 10:04 PM
JAkridge
Default Fluttering - Jittering Servos
The full system is tuned on TX & RX both. One airleron servo will flutter-jitter as much as 1/4" up and down. I have just purchased a Hitec Battery Checker II and the battery is at 75% (1100mah pack). All surfaces work fine when useing the sticks. But as soon as you stop moving joy sticks the flutter-jitters come back.
Battery Low ??
Radio ????
