Will this work?
Reply
Old 07-11-2005, 07:33 PM
Edge 540
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Will this work?
I have a good digital multimeter what will do a lot more than I know how. I don't think that it can test my RX battery under load though. This is my plan:
Plug a lead into a spare channel on the RX, remove the white signal wire, and solder on a plug which I can plug my multimeter into. If I turn on my receiver and operate all of the servos at once while the multimeter is plugged into a spare channels's positive and negative leads, will it show what my battery voltage is under flight conditions? (approximately?)
Edge  540 is offline
Old 07-11-2005, 08:56 PM
ALbert.S
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Will this work?
Yes Or go to Radio Shack and purchase a 10 ohm 10 watt resistor and connect it across the meter leads and then plug into charge jack on your aircraft This will put a 1/2 amp load on yyour batteries and should give you a steady load that your meter can read easily. The receiver switch will be in the off position of course. If you want to test the transmitter batteries put a 20 ohm resistor across the leads and plug into charge jack. Thats two 10 ohm resistors in series You will get 2 when you go to Radio Shack because they come 2 to a pack
ALbert.S is offline
Old 07-12-2005, 11:25 AM
apteryx
apteryx's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes
apteryx is offline
