radio receiver problems
Reply
Old 07-16-2005, 03:12 PM
vapour trail
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default radio receiver problems
HI THERE EVERYONE
I AM LOOKING FOR SOME POSSIBLE ANSWERS TO MY RADIO AND RECEIVER TROUBLE I AM HAVING>I AM USING A FUTABA ATTACK TD2R RADIO 27MHZ
WITH A R132JE RECEIVER.WHEN I RANGE CHECK AND WALK AWAY FROM THE MODEL AT ABOUT 8 FEET THE TWO SERVOS START GOING CRAZY .THE RANGE CHECK IS DONE WITH THE TRANSMITTER AERIAL DOWN BUT DOES NOT STOP THE PROBLEM WHEN FULLY EXTENDED>DOES ANYONE KNOW WHATS WRONG AND ANY SOLUTIONS>ANY HELP WOULD BE APPRECIATED.
THANKS LEE>
vapour trail is offline
Old 07-16-2005, 03:19 PM
aeajr
aeajr's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: radio receiver problems
1) Check the antenna to make sure it has not become detached inside the receiver
2) check to see that the antenna on the radio is screwed in all the way.
3) Open the radio and make sure the bracket that attaches the antenna to the radio is solidly attached.
4) Is there an ESC involved? Do you have the same problem with the ESC removed?
5) Try with one servo. Then the other, and so on. Might be a servo problem.
6) try moving the battery around. Any change?
If these all come up negative, then I would suspect a problem in the receiver itself or the radio. Pack 'em both up and send them to the maker.
aeajr is offline
Old 07-16-2005, 03:25 PM
vapour trail
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks For your help I will try all of those and see what I come up with
Old 04-26-2006, 03:14 PM
vapour trail
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
HI THERE,
DOES ANYONE OUT THERE OWN A RC SKYDIVER.IF SO DO YOU KNOW HOW TO OPEN THE CHUTE PACK USING THE SKYDIVERS LEGS.I KNOW MANY USE THIS SYSTEM<BUT I DO NOT KNOW THE SET UP FOR IT.ANY HELP WOULD BE APPRECIATED.
Old 11-12-2007, 03:57 AM
rcryno
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi, ive only been into rc for a year, and when i bought my first "real" rc, i didnt even know it. lol.
It was a RC18T clone, and im addicted to rc now . Anyway, ive had to have the motor replaced and the servo a few times. And i was running it the other day and i crashed into a curb, (first real crash ever) and after reattching the front left wheel i went to drive it again and the range would only go about a meter or so, so i pulled apart the receiver and it looked all good, but the range was still about a meter. Does anyone know what the problem could be, im going to my LHS this weekend and want to try and avoid buying a new receiver (cause im only a kid).
Thanks guys, it would b great if any1 came up with a soulution.
rcryno is offline
Old 11-12-2007, 08:35 AM
aeajr
aeajr's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You have told us nothing about the radio system; Brand, model of receiver, anything. Makes it hard to help you.
However here are some thoughts.
1 Loose crystal
2 Broken crystal
3 antenna wire that is still attached, but just barely.
aeajr is offline
Old 11-12-2007, 08:33 PM
A.T.
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: rcryno Hi, ive only been into rc for a year, and when i bought my first "real" rc, i didnt even know it. lol. It was a RC18T clone, and im addicted to rc now . Anyway, ive had to have the motor replaced and the servo a few times. And i was running it the other day and i crashed into a curb, (first real crash ever) and after reattching the front left wheel i went to drive it again and the range would only go about a meter or so, so i pulled apart the receiver and it looked all good, but the range was still about a meter. Does anyone know what the problem could be, im going to my LHS this weekend and want to try and avoid buying a new receiver (cause im only a kid). Thanks guys, it would b great if any1 came up with a soulution.
Smashing RC cars into curbs is never good for the wallet. Few RC cars have any vibration protection for the receiver and if the aerial is undamaged, extract the crystal and gently shake it next to your ear. If it rattles then it will need replacing. No rattle,. check if your receiver is AOK with a crystal of same band (27, 29, 35, 40 04 75? etc) from a friends car and their TX or try your crystal in their RX with your TX - if inoperative, buy a new crystal. If working, then in all probability you have broken the ceramic filter and it is usually cheaper to buy a new 2ch AM RX than get it repaired unless you have good DIY skills. (A new FM RX is also now often cheaper than repairing an old one.)
More information for DIY repairs under "Radio Systems, Accessories, Alterations and FAQ".
Regards
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
A.T. is offline
