pcm 1024 help fp-r129dp
pcm 1024 help fp-r129dp, Does anyone have infomation on this receiver or a link to information about this receiver. It was given to me and I really dont know a lot about it. For example what does the C stand for.... it is located in the same line-up as the C,1,2,3,4,5,6,7,8,9/B where you plug in the servo leads. Anyway any help would be welcomed and thank you.
RE: pcm 1024 help fp-r129dp
It was disontinued in 1998 but its narrow band so its certainly useable.
Its a 9 channel Dual Conversion PCM 1024 reciever.
http://www.futaba-rc.com You'll have to look through the manuals of the radios till you come across one that was packaged with that reciever but my guess is the C is Control or DSC where you could plug the radio into the reciever and control the servo's without transmitting. Like making adjustments while the freqency pin you needed was in use.
You can also try the futaba direct support forum, Bax or Krysta should be able to give you some more info.
