Enterprise FIX ??
Reply
Old 07-27-2005, 10:49 PM
ljhmc
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Enterprise FIX ??
I know I have been asking a lot of questions about mixing the rudder with the ducted fans and having the fans always on. I think I know the reason: the rudder is the master and the Ducted Fans are slaves to the rudder. At netural the rudder is putting out 50% thus the fans are running. At full left or right the fans are running at ful speed.
Question: Can this be corrected to the point they are off when at netural and move to full speed when the stick is moved to the left or right?
Thanks for all the help and understanding everyone has given and put up with in my troubles.
Lawrence
Omaha Nebraska
ljhmc is offline
Old 07-28-2005, 04:38 AM
mglavin
My Feedback: (31)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Enterprise FIX ??
I think you discovered the problem... It makes perfect sense if OFFSET is not active at 100% and Rate is at 100% on both slaved rudder/slave mixes. You may have to use servo reverse to get the ESC’s to work as needed, otherwise one fan may operate and the latter not.
mglavin is offline
