Eagle Tree Announces Flight Data Recorder V2 (FDRV2) Enhancements!
Reply
Old 07-29-2005, 07:27 PM
billpa
billpa's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Eagle Tree Announces Flight Data Recorder V2 (FDRV2) Enhancements!
Hi All,
You have asked us for new features and capabilites, and we heard you!
Eagle Tree is proud to announce several enhancements to our Patent Pending Flight Data Recorder V2 data logging system. Whether you need to know your speed, current draw, temperature, RPM, or just about anything else, the V2 is for you . The built-in capabilies of the tiny, low cost V2, coupled with its robust expansion capability and optional sensors, make it the only data logging system you will ever need to buy.
As always, the FDR V2 provides the following features:
* Airspeed to 290 MPH, and altitude to 30K feet, with included sensors
* Up to two temperatures with our standard sensors, and up to 2 more with our EGT expansion module (1 temp sensor included standard)
* Electric current to 100 amps, and voltage to 50 volts, utilizing our optional slip-on current sensor ring. This sensor is unique in that it is passive (NOT in the current path) which eliminates a failure point.
* 4 servo channel position and glitch monitoring with the included heavy duty Y cables.
* Receiver battery voltage monitoring is built in.
* RPM monitoring up to 50K with the included RPM sensor.
* Dual axis G-force with our optional g-force add-in module.
* Real time clock for flight playback and graphing
* Fully compatible with both 4.8 and 6 volt electric, nitro and gas birds.
* USB download, and USB live mode for real time bench monitoring.
* Full compatibility with our Seagull Wireless Dashboard expander, for real time wireless LCD flight monitoring of all parameters with programmable alarms.
* Included Windows app provides virtual cockpit, full graphing support, and Excel compatible file output.
* 1 Year warranty, and 30 day money back guarantee if not delighted.
Here are some of the enhancements of the "New V2":
* Recording memory is increased by 4X. With our built in lossless compression, and with adjustable sample rate and logged parameters, record times of several hours are now easily obtained.
* System accuracy has been improved by using state of the art micro-reference circuitry.
* Increased altitude and airspeed sensitivity and accuracy due to improved noise immunity and temperature compensation circuitry.
* Upgradable for use with our soon to be released GPS module expander.
And best of all, the FDR V2 is available for around $170 bucks! Compare our features with the other loggers out there, which provide you with just a couple of parameters, and we think you'll agree that our system is a great value.
To purchase, see your dealer, or order directly from us on the web:
http://www.eagletreesystems.com/Plane/plane.html
And don't hesitate to email us or post any questions you may have about our products.
Happy Flying!
Bill Parry
Eagle Tree Systems, LLC
billpa@eagletreesystems.com
billpa is offline
Old 07-29-2005, 08:31 PM
mglavin
My Feedback: (31)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Eagle Tree Announces Flight Data Recorder V2 (FDRV2) Enhancements!
Bill
What are the current and voltage recording specifications, i.e. sample rate interval and or resolution?
mglavin is offline
Old 07-29-2005, 08:49 PM
billpa
billpa's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Michael,
Resolution is 12 bits, and the values are sampled constantly and averaged to 10 s/s. We are offering a Pro model very soon which will have higher sample rate and resolution options.
Bill Parry
billpa is offline
Old 07-29-2005, 09:16 PM
mglavin
My Feedback: (31)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Bill
Thanks for the info.
mglavin is offline
Old 10-02-2005, 02:29 PM
Blue Collar Sound
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Bill
Will the new gps module support moving map software?
Mark
Blue Collar Sound is offline
Old 10-03-2005, 10:42 AM
dirtybird
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have your current unit. How much to upgrade?
Do you really have to have 30 k ft altitude? I tried to get my 1/3 scale to 1000 feet and found I couldn't see it well enough to fly it over 850 ft.
What is the current measurement resolution?
dirtybird is offline
