Transmitter question
Reply
Old 08-07-2005, 02:22 PM
merx9
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Transmitter question
I recently bid on a futaba transmitter on ebay and i noticed it didnt come with servos like alot of other ones on ebay. ANyways my question is if i do win the auction do i need to go buy special servos to support the transmitter? or do any servos work. Also The transmitter is a futaba magnum 2pl if i do need to buy things for it to make it work what would they be?
thanks for any help
merx9 is offline
Old 08-07-2005, 04:26 PM
guver
My Feedback: (325)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Transmitter question
any standard futaba made servos will work, opther brands may work also.
guver is offline
Old 08-07-2005, 06:08 PM
merx9
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ok so i should buy what? if it doesnt work? sorry im kinda new to all of this.... Servos recoever? or what thansk again
merx9 is offline
Old 08-07-2005, 06:36 PM
Mad Wax
Mad Wax's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Speak English. What did you buy- is the RX included? What model plane/car/boat is this for? Model size (larger scale require higher torque servos)
If the TX/RX is HRS you HAVE to use digital servos. If it's PCM can use digital or analogue. The 2PL kit comes with 2x S3003, as well as a power switch, TX & RX and a 4.8v battery cage.
Mad Wax is offline
Old 08-07-2005, 10:35 PM
merx9
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
http://cgi.ebay.com/ws/eBayISAPI.dll...MEBI%3AIT&rd=1
is what i bid on im going to be using it in a tmaxx.... now what do you think i need?
merx9 is offline
Old 08-07-2005, 11:50 PM
mglavin
My Feedback: (31)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You'll need a receiver, battery, servos and switch harness. If it goes for under $30.00 I'd suggest its a great deal.
Is the TMax electric or gas?
mglavin is offline
Old 08-08-2005, 12:24 AM
merx9
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Its a gas tmaxx
Do you recomend any specific receiver, battery, servos and switch harness?
merx9 is offline
Old 08-08-2005, 01:02 AM
mglavin
My Feedback: (31)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A 75mHz two channel RX and you'll need to find out what channel the TX is on. Futaba and or Hitec RX's are compatible with this TX. I suggest Hitec's HP-2RNB 2 Ch AM RX plus crystal on the appropriate channel, 6 Volt NiCad battery 600mAh battery, HD switch harness with charge jack and two HS-645 metal geared high powered analog servos. You'll need a battery charger for the RX battery pack. A standard wall charger will work for Hitec but its lacking, an auto peak charger would be best and multi-purpose too.
Do not use alkaline batteries on high torque servos, you want high torque servos for steering and braking. Standard power servos will work but are lacking IMO.
mglavin is offline
Old 08-08-2005, 01:18 AM
merx9
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thanks for all the info mglavin seems like it will be an expensive purchase in the end though.. thought id be saving alot of money or something
merx9 is offline
Old 08-08-2005, 06:36 AM
piper_chuck
My Feedback: (12)
piper_chuck's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: merx9
Probably not. This radio is $70 at Tower, http://www2.towerhobbies.com/cgi-bin...I=LXENN3**&P=0 and you can often get some kind of discount. eBay is a difficult way for beginners to get stuff, it's hard to know if you are getting a good deal.
piper_chuck is offline
Old 08-08-2005, 04:11 PM
guver
My Feedback: (325)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
that is a tx only, it is 2 channel. A t-maxx needs 3 channel if you are using reverse.
guver is offline
Old 08-08-2005, 09:48 PM
aeajr
aeajr's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: merx9
Read!
Radio Systems Part 1 - Standard Radios
http://www.rcezine.com/cms/article.php?cat=&id=44
Radio Systems Part 2 - Computer Radios - A Better Investment
http://www.rcezine.com/cms/article.php?cat=&id=65
aeajr is offline
Old 08-08-2005, 10:17 PM
Cyclic Hardover
Cyclic Hardover's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hitecs will work fine too and a Hitec Receiver
Cyclic Hardover is offline
Old 08-09-2005, 02:20 AM
merx9
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Guver is that correct i wont be able to use reverse with that remote? If so i can put it in my mt2 or maybe sell it with my yokomo gt-4 we'll see what happens with the bid...
aeajr thanks for the links helpful read
merx9 is offline
Old 08-09-2005, 07:51 AM
guver
My Feedback: (325)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have an e-maxx that uses 3rd channel for 2nd gear, but the t-maxx uses it for reverse I am pretty sure. The t-maxx uses a 3 channel radio from the factory and the 2pl is a 2 channel.
guver is offline
