JR 9x2 tx mixing setup help please
Hi All,
I'm having trouble making sense of a function on my 9x2. I have a wing with 4 servos in it. I need to mix the two outboard ones to the aileron function, and the two inboard ones for flaps.
I realise I could y lead the ailerons, but I need to adjust them digitally. I've read the pages in the manual, but I'm not getting anywhere fast and wondered if anyone would be good enough to do an 'idiots guide to mixing on the 9x2'
Sorry, if this is somewhat of a tedious matter, but I can't get past the problem.
Thanks in advance,
Dave
Thanks in advance,
Dave
RE: JR 9x2 tx mixing setup help please
Guys, I'm still having difficulties with the above problem, if anyone can help. it would be appreciated.
Also, can anyone tell me if it's possible to reassign the throttle cut switch to another switch, prfereably one that isn't sprung.
Many thanks,
Dave
Many thanks,
Dave
Wing set-up.
Flaperon operation uses Ch2 and Ch6.
If you want to adjust aileron differential from the Tx you will need 2 matchboxes. (1 in ea wing for aileron operation)
If you do not need to adjust differential from your Tx then 1 matchbox would work with all 4 aileron leads plugged in. The matchbox in this case would plug into Ch 2 and you would not use the Flaperon mix.
1 Matchbox for all 4 flap servos.
For throttle cut use a program mix and mix throttle to throttle. Adjust the cut-off position as a %.
You can then assign say the gear switch to activate the mix.
Hope this helps
Alan
Hope this helps
Alan
