Can I do this?
Reply
Old 08-08-2005, 05:50 PM
jcflysrc
My Feedback: (50)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Can I do this?
I have a wall charger that came with a Futaba Tx, and I'm wondering if I can use it to charge a JR Tx? Plug seems to be the same.
Jim C.
jcflysrc is offline
Old 08-08-2005, 06:25 PM
Dewey2
My Feedback: (24)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Can I do this?
No wrong polarity.
Dewey2 is offline
Old 08-08-2005, 06:32 PM
JohnBuckner
JohnBuckner's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes it can be done and will work fine. MAJOR WARNING however JR uses reversed polarity on their TX charge jacks, Center pin negative. All the other major manufacturers use center pin positve on their Tx charge jacks.
If you plug an Airtronics, Futaba or Hitec wall charger into a JR tx the JR fuse will be blown and even additional damage can result.
The solution is to simply cut charger wires somewhere in the line reverse polarity, solder and shrink wrap. I have a number of JR wallchargers reversed to use with Hitec Tx's. Always remember JR only uses Center Pin Negative.
John
JohnBuckner is offline
