servo reversing
servo reversing
How can i make my servo reverse without fliping it or switching the arm or using my transmiter?
its in a heli and i cant flip it or do anyof that stuff...
is there a way by switching the wires inside the servo or something easier???
GA
RE: servo reversing
usually no.... reversing the wires will not work as there are internal electronics that you would need to change
you will have to do one of the above...
or change the servo..
ie: Futaba goes one way, Hitec goes another, etc. etc.
Most...if not all transmitters allow for a channel reversal.... what Tx are you using????
ND
RE: servo reversing
i wouldn't trust a gws servo anywhere close to a heli!!! I bought 6 of them last year, none are around anymore this year. I would say none made it longer then 10-20 flights total!!
anyway, what heli/tx are you flying that you can't just flip a switch?
RE: servo reversing
very easy to do if you know how to handle a soldering iron. the two outer wires of the pot need to be switched around and the same needs to be done to the pair of wires going to the motor. the surgery can be done to the circuit board or to the terminals of the pot and motor, whatever looks easiest.
dave
dave
