receiver position
receiver position
I have had several problems with radio installation in my c.g. freedom 20 trainer.
After changing the whole radio equipment( emitter and receiver) I would like to correct as well something I think could be incorrect.
Layout is:
Battery is just behind firewall and under the tank, (foam wrapped)
Behind this is located the receiver and the next is servo trail, so receiver antenna pass ( about 3" ) over or under the servos.
Is this ok?
Layout is:
Is this ok?
My Feedback: (31)
receiver position
This should work fine, I have seen this done numerous times. However I would try and route the antenna wire away from all other wires, pushrods, servos, battery and switches. This is preferred method.
Do a range check with and without the engine running to verify range.
NM
Wiring ?
What Michael says is true. Just try and keep the receiver and it's antenna, seperated from all power, and servo wiring.
Your criteria should be a good range check. About 50 paces with your Tx antenna collapsed.
Jim Lynch - Forum Moderator
