JR 10X Smoke Setup
JR 10X Smoke Setup
Hi Guys,
Checking to see if any of you have set up your JR 10X with smoke linked to your throttle? I have mine on the gear switch but I’d like to be able to reduce or shut the smoke off when I bring the throttle down. If any of you have experience with this and could explain how to set it up I would appreciate it.
Miles
Miles
RE: JR 10X Smoke Setup
You can mix an unused channel to the throttle. Either use a linear mix or you can use a multi-point mix to control the amount smoke oil flow. Hope this helps.
