JR transmitter
JR transmitter
I have 3 JR max 4 tx. One works fine but the other two will not accept a charge through the jack. I used a multimeter to check for power but came up empty handed. They still transmit fine but the light will not go on on the charger. I am using a Futaba charger with the polarity reversed. I have never used JR in the past so they are new to me. Any help with this problem or any others I may encounter, would be appreciated.
Soulman
Soulman
JR transmitter
I have tried every conceivable combo with no luck. I should add that on the charger, I added the JR tx lead to the Futaba lead thinking that this way I could measure the battery level by using the multimter on the unused lead. I don't think I crossed anything but... What could I have done? The radio does not have a fuse according to my local hobby store. Thanks for your reply.
Soulman
Soulman
OH
JR transmitter
soulman
The Max4 radios have an IC protector type fuse in the charge circut. Look around the charge socket on the circuit board for a transistor looking thing with two legs instead of three. If I remember correctly the IC protector had N75 printed on the flat side. Follow the tracers and they will lead you to it. Check it with a volt meter and you will probably find that there is power on the batt side and not the charge socket side.
I don't know if these numbers will do you any good but this is what I replaced mine with;
ECG 15023 A-IC Protector, 1A
I had to go to a electronic supply company to get the protectors. I tried Radio Shack and the like and got the deer in the headlights look.
Hope this helps
DEG
Hope this helps
DEG
My Feedback: (506)
JR transmitter
I've had a similar problem with my both of my 10X radios. On both radios there was a little trace on the PCB inside the battery cartridge that opened up (probably from me fast-charging at too high a rate.)
Soldered in a jumper and no more problems.
JR transmitter
You guys are the BEST!! I have not tried it yet but just the overwhelming response and outpouring of help reinforces why I joined this group. Thank You!
BC, CANADA
RE: JR transmitter
ok, i think im in the right place. I got the JR max4 radio and i just bought a charger that is piranha digital peak charger. my question is:the battery pack of the transmitter is made of 8AA's,now this charger asks if the battery is nimh or nicd, and there is nothing on the battery pack other than its a 600 mah. Is it right to assume that all the AA batteries are nimh??? another thing,since i dont have the right plug that connects the charger to the transmitter,is it ok to take out the battery pack and charge it? or it should be charged while its in the transmitter,fuses and all??
thanks in advance
thanks in advance
