Changing frequency
OH
Changing frequency
I was wondering what all was involved in changing the frequency of my transmitter. I have Rx's on two different channels (20 & 25). The Tx came on channel 20 and I have a Tx crystal for Channel 25. All Tx parts are Futaba. All Rx are micro GWS.
OH
RE: Changing frequency
Just so everyone knows, it's obvious that you just pull out the crystal and replace it. I was wondering if that was all that had to be done. I had heard somewhere that you're not allowed to change out the Tx crystal because the Tx then needs to be tuned to the new frequency.
Here's a spoon to stir that can of worms you just opened.
Legally you can't change your tx crystal w/o sending it in to get tuned UNLESS your using the plug in RF modules that the newer Futaba transmitters use. FCC rules regarding type acceptance, AMA liability issues etc.
Do a search theres PLENTY of info.
If your smart, the safe way to do it is replace the crystal so that both recievers are on channel 20.
OH
I went to the manufacturer's site for my radio (futaba-rc.com) and did a little research.
Under the "How do I change the frequency of my transmitter?" on the FAQ it lists the following FCC stuff...
I've done some work for the Feds in the past, so I understand how there is a lot of red tape and inconsistency in their guidelines (I almost lost my job once because I moved a piece of furniture to get something I had dropped; it was somebody else's job to move furniture and I was supposed to call them to move it for me to get my pen). But what I understand of the above is the following...
[*]I'm not allowed to change the crystal.[*]Anything that I can manipulate/adjust on the radio without disassembling it is okay.[*]Plug-in crystals must not be accessible to the end user
According to the above, that little pull out modular thing that says 72.xxx on the outside of my radio can't be the crystal (although it looks like one to me) because I can manipulate it without opening the radio enclosure and it is very accesible. If the argument exists that the radio enclosure is opened by pulling that out, then taking the battery out would also be illegal. And if it is the crystal, then futaba (and just about every other Tx manufacturer) isn't following the law. It's like watching a cop speed or roll through a stop sign when he's not responding to a call.
I'm not trying to find a loophole. It's just as easy to drop $7 on a Rx crystal. But I may need to change it at some time and it seems rather far fetched that swapping out a crystal without touching/modifying any circuitry would be likely to cause any problems. I can relate to the idea because I don't want end users at work touching my machines; you use it, I fix it, don't touch it otherwise. But you can readily buy everything you need to swap out your crystal in any hobby store and can complete the switch in less time than it takes me to type out this post, but it's illegal to do so?
I guess my only other approach is trying to find out what it takes to become licensed to swap crystals out. Any ideas on where to start looking for that info?
The applicable Federal Regulation is as follows:
TITLE 47—TELECOMMUNICATION COMMISSION (CONTINUED)
PART 95—PERSONAL RADIO SERVICES
Subpart E—Technical Regulations
Sec. 95.645 Control accessibility.
(a) No control, switch or other type of adjustment which, when
manipulated, can result in a violation of the rules shall be accessible
from the transmitter operating panel or from exterior of the transmitter
enclosure.
(b) An R/C transmitter which incorporates plug-in frequency
determining modules which are changed by the user must be certificated
with the modules. Each module must contain all of the frequency
determining circuitry including the oscillator. Plug-in crystals are not
considered modules and must not be accessible to the user.
enclosure.
ORIGINAL: deli_conker
<<<snip>>>
<<<snip>>>
The cop analogy doesn't apply in Texas. Certified peace officers here are exempt from many of the traffic laws they enforce.
I do not know the licensing requirements to be able to swap Tx crystals. I'd guess the FCC web site has the info buried somewhere. The cost of the equipment required to properly test, and potentially recalibrate, transmitters would buy a bunch of receiver crystals.
It is my equipment. I am responsible for the equipment. I should be able to check it.
Bill
OH
When the transmitter was built, it was glued in with a tiny drop of glue to make it 'inaccessible' to the end user in the US.
inaccessible
adj 1: capable of being reached only with great difficulty or not at all [syn: unaccessible] [ant: accessible] 2: not capable of being obtained; "a rare work, today almost inaccessible"; "timber is virtually unobtainable in the islands"; "untouchable resources buried deep within the earth" [syn: unobtainable, unprocurable, untouchable]
Either the FCC or Futaba needs to get a recent dictionary because the crystal is anything but inaccessible.
My Feedback: (12)
SC
This discussion just keeps going round in circles, thread after thread. The following post, in one of many recent discussions on the same subject, sums up the FCC regs pretty well: http://www.rcuniverse.com/forum/fb.asp?m=3256728
The bottom line is Joe Sixpack can't change the Tx crystal. There are a few misguided individuals who think otherwise, and no amount of discussion is going to change the regs or the minds of those who choose to (mis)interpret them to suit their own opinion.
Most manufacturers 'protect' their service centers by making it very difficult for the average person to get the info they need to work on their equipment. Sony and RCA do not make service manuals readily available; they want you to pay them. RC transmitter makers and distributors are the same way. If they publish the testing procedures they lose revenue.
Is money the only motivation? Who knows?
It really doesn't matter what Futaba, FCC, AMA, or anyone else thinks; you're either going to change the crystal or you're not.
WA
I wouldn't worry to much about changing freqs., unless you change to the 50mhz band as that is Amateur Radio band and requires a license! The fine for intentional operation without a license is $10,000.00. And it IS enforced!..
Have a good day!
Have a good day!
The user must insure that when they use their transmitter, it complies with the technical specifications for the R/C Service. If you cannot do this, you must have someone do it for you.
To change a transmitter crystal, you first swap out the old crystal for the new one. You then turn on the transmitter, extend its antenna, and put it in the location required to use your spectrum analyzer. The spectrum analyzer will have a calibrated antenna. You check the center frequency, and adjust it as necessary. You check the power output, and adjust as necessary. You check the FM deviation, and adjust as necessary. You check the bandwidth and adjust as necessary. Finally, you check the analyzer's display at a wider bandwidth to double-check the skirts of the output spectrum.
If you have the proper equipment and training to do this, you are qualified to perform a frequency change.
The applicable FCC regulations can be found at:
http://www.access.gpo.gov/nara/cfr/w...7cfr95_03.html
The technical requirements for R/C are in Part 95, Subpart E, which starts at 95.601. If you don't understand these requirements, and/or don't have the equipment to insure your transmitter complies with them, then you are not considered to be qualified to change the frequency of your transmitter.
An FCC General Radiotelephone Operator License is no longer required to work on R/C transmitters, but most RF service shops have at least one person who holds that license. Even so, without the proper test equipment, even a trained/certified individual cannot assure that a transmitter complies with its technical requirements. How can the untrained layman?
OH
Wow. Looks like people were getting pretty angry in that last thread.
I read through the regs page (twice) and by reason of the way Section 95 is written (vagueness, confusing references, etc.), am thoroughly convinced that the FCC is a government entity. I was half expecting a reference to a flux capacitor in there somewhere...
I understand why you wouldn't want to just change the Tx. That's a no brainer. I sent the FCC an email asking them who is "certified as technically qualified" in the following excerpt from Sec 95.221(b)
The internal repairs or internal
adjustments should be performed by or under the immediate supervision
and responsibility of a person certified as technically qualified to
perform transmitter maintenance and repair duties in the private land
mobile services and fixed services by an organization or committee
representative of users in those services.
Hopefully they get back to me within a month or so. Pending on what they say, I may just have to trade my 7CHP in on an Eclipse w/ spectra module. We'll see.
OH
Still no word back from the FCC. So I did some research on spectrum analyzers though. I think I'd rather buy a couple of new cars than buy one of those so I can legally change out my crystal.
The reason I wanted to change crystals is because the closest flying field (which I don't fly at) tells people that they don't fly on channels 20 and 21 because of broadcast TV interference. Well guess what? My radio is on channel 20. I don't fly at the field because I fly parkflyers and don't need the space they have or the dues/fees etc. that they charge to do so. I don't need a range of more than 2500 feet either. But that doesn't mean that I want my $150 Cessna to go down because of a tv broadcast either. By the way, I found all of this out after buying the radio.
I fly at a couple parks. The closest one is around 5 miles away from the flying field, the other is around 15 miles away. I am assuming that the TV broadcast is going to hit my radio at either place so I wanted to get a channel change. I went to my LHS and bought the crystals necessary to put it on channel 25. That's when I started reading the manual that came with my radio and found out all the rules etc. I took the crystals back yesterday and asked the LHS guy about the whole thing. He chuckled, but took the crystals back anyways.
Is the broadcast really going to have an effect on my radio gear like I think it might?
Is the park that's farther away going to be safe(r) to fly at on this channel?
OH
What would you consider as close? Obviously they think it is close enough to them to prohibit those 2 channels. But I don't know if they are right next door to the broadcast either...
I've seen channels prohibited because someone read something in a magazine so that doesn't mean much.
Can you see the towers from the field or on the drive out there? I've flown on 20 where you could see the towers and they didn't cause any problems. I had to prove it with a freqency scanner that it wasn't a problem but they finally caved and told me it was my plane.
ND
my former field was located about 500 ft from some tv broadcast towers, all channels worked great. although about once or twice a month EVERYONE would get strange hits... usually enough that we would just pack up and leave for that day, i'm assuming it had something to do with the towers.
OH
Ok. I went to my normal flying park and checked out channel 20. Aside from something totally unrelated happening to my slow stick, everything was fine. I'm glad people kept their cool in this thread, unlike the other though. I can see the frustration about not being able to change channels ourselves, but also see the reasons why it's not always a good idea. At this point, for me at least, it's much ado about nothing as the nearest flying field is afraid of flying on my channel which means I won't have to worry about messing with them and I know that they won't be messing with me.
My brother is into ham radio, so I'm going to give him a call about it just to hear his viewpoint on frequency, tuning, etc. He may actually have the stuff necessary to make the "legal" changes. I'm still waiting to hear back from the FCC to see what they have to say though. I think I'm going to keep pressing this issue with them just so that the RC community may have some "official" resolution in this matter (assuming they care enough to write back).
ND
spread spectrum systems exist for ground vehicles, just haven't made it to air use yet) Worse yet, the fcc could come down heavy handed and take away the 72/75 bands, forcing manufacturers to move up to unregulated 2.4 or 900mhz. Your existing crystal based equipment would be worthless and illegal to operate. (has happened before, and probably has come very close a couple of times)
kc0lmo
or maybe radio manufacturers would quit using 1950's era technology!
Bill
NC
Just to muddy the waters further, if you go to HiTec's website and look up support info on their Ranger III FM (75 Mhz Surface radio) they give instructions on how to pull the crystal and change the frequency.
Click on Ranger 3 FM: http://hitecrcd.com/homepage/nsupport_SFS.htm
I would also point out that the surface people (boats, and I guess cars) think the "you can't change your frequency" thing is an AMA rule. They explain that there's no way they can have a race with 20 boats on the water at once at their Nats unless people can change frequencies. They have a point!
But of course, they can afford to be a bit more casual because a frequency conflict won't crash their boat into the ground from 300 feet up!
OH
I finally heard back from the FCC. They also sent me a pdf that I will happily forward on to anybody who pm's me an email address.
From the fcc...
You are receiving this email in response to your inquiry to the FCC.
GENERAL RADIO OPERATORS LICENSE (GROL) (PG)
A PG is required to adjust, maintain, or internally repair FCC
licensed radiotelephone transmitters in the aviation, maritime, and
international fixed public radio services.
WEB ADDRESS: http://wireless.fcc.gov/commoperators/testing.html
THE FCC DOES NOT ADMINISTER COMMERCIAL OPERATOR LICENSE
EXAMINATIONS. To obtain a new or upgraded FCC commercial operator
license, you must pass an examination administered by a COLE
Manager. The COLE Managers listed below are authorized by the FCC
to administer examinations nationwide and, in some instances, at
foreign sites. Upon passing the examination(s), the COLE Manager
will issue you one or more Proof of Passing Certificates (PPC)
that you include with your license application package that you
or the issuing COLE manager files with the FCC.
BFT TRAINING UNLIMITED INC: 1318 Redwood Way, Suite 220,
Petaluma, CA 94954. All elements are available at regularly
scheduled times or by appointment from 150 examiners throughout
most of the United States and U.S. Territories, as well other
locations by prior arrangement. Fee: $75.00 per 1-2 exam
elements, with a minimum fee of $75.00 per exam. Contact: J.
David Byrd PHONE: 800-821-0906 or 707-792-5678 FAX: 707-792-5677
Internet: www.elkinstraining.com E-mail: [email protected]
ELECTRONIC TECHNICIANS ASSOCIATION INTERNATIONAL, INC. 502 North
Jackson St., Greencastle, IN 46135 All elements are available at
test sites located throughout all states, including all U. S.
military installations (DANTES). Call for schedule information.
Examinations are also available by appointment. Fee: $50.00 per 1
or 2 exam elements. Contact: Richard Glass PHONE: 765-653-4301
or 1-800-288-3824 FAX: 765-653-4287 Internet: www.eta-sda.com,
ELKINS INTERNATIONAL, INC. P.O. Box 797666, Dallas, TX 75379
Examinations for all elements are available at regular scheduled
times or by appointment at Elkins' test centers throughout the
United States, American Territories and installations overseas.
Fee: $25.00 per element, with a minimum of $50 per exam session.
Contact: Laura Elkins PHONE: 888-621-8876, E-mail:
[email protected]
INTERNATIONAL SOCIETY OF CERTIFIED ELECTRONICS TECHNICIANS
(ISCET),3608 Pershing Avenue, Fort Worth, TX 76107-4527 All
elements are available by appointment from 360 examiners in 47
states, Guam, and selected foreign countries. (Alaska, Vermont,
and Wyoming not presently available.) Fee: $35.00 - 75.00.
Contact: Alice Brown - Dept. 19 PHONE: 817-921-9101 FAX: 817-921-
3741 Internet: www.iscet.org, E-mail: [email protected]
LASERGRADE COMPUTER TESTING, INC, 821 SE McGillivray, Ste 201,
Vancouver, WA 98683. All written elements are available at more
than 500 sites throughout North America and internationally. Fee:
$60.00 for the first element and $30.00 for up to two additional
elements per day. Computer based testing is offered on a daily
basis throughout the year. Contact: Linda Small PHONE: 800-211-
2753 FAX: 360-891-0958 Internet: www.lasergrade.com, E-mail:
[email protected]
MARINE TECHNICAL INSTITUTE,1915 S. Andrews Avenue, Fort
Lauderdale, FL 33316, All elements are available daily by
appointment at test sites in fifteen states. Fee: $50.00 for the
first 2 Elements (minimum sitting fee $50.) and $25.00 for each
additional Element per sitting. Contact : David Greenspan PHONE:
954-525-1014 FAX: 954-764-0431 E-mail: [email protected]
THE NATIONAL ASSOCIATION OF RADIO TELECOMMUNICATIONS ENGINEERS,
INC. (NARTE) P.O. Box 678, Medway, MA 02053. Fed Ex: 167 Village
Street, Medway, MA 02053. All written elements are available at
more than 270 civilian and military testing centers in the US and
worldwide. Testing available quarterly and by appointment
(depending on location). Fee: $40.00 for up to 3 exam Elements.
Call for schedule and registration information. Contact: Sandy
Felone - FCC Examination Registration and testing site
information PHONE: 1-800-89-NARTE or 508-533-8333 FAX: 508-533-
3815 Internet: www.narte.org E-mail: [email protected]
NATIONAL RADIO EXAMINERS, P.O. Box 565206, Dallas, TX 75356-5206.
UPS or Fed Ex: 2000 E. Randol Mill Rd., Suite 608-A, Arlington,
TX 76011. All examination elements are available at more than 250
test centers across the US and in some foreign countries. Fast
electronic filing to the FCC results in almost immediate receipt
of license. Fee: $35.00 per license Contact: Larry Pollock PHONE:
817-860-3800 FAX: 817-548-9594 Internet: www.radioexaminers.com
SEA SCHOOL, 8440 4th Street North, St. Petersburg, FL 33702. All
elements are available by appointment in 83 coastal cities and
at 200 airport cities around the country. Fee: $25.00 - $55.00
Contact: Mary Foster PHONE: 1-800-237-8663 FAX: 727-522-3155
Internet: www.seaschool.com E-mail:[email protected]
Examinations
To obtain an FCC Commercial Operator License, applicants must
submit, to the Commission, proof of passing written and/or
telegraphy Elements as illustrated in the following table.
Each Element is described after the table.
Type of License Written Elements Telegraphy Elements
First Class Radiotelegraphy Operator's Cert 1, 5, 6 3, 4
Second Class Radiotelegraphy Operator's Cert 1, 5, 6 1, 2
Third Class Radiotelegraphy Operator's Cert 1, 5 1, 2
General Radiotelephone Operator's License 1, 3
Marine Radio Operator's Permit 1
GMDSS Radio Operator's License 1, 7
GMDSS Radio Maintainer's License 1, 3, 9
Ship Radar Endorsement 8
WRITTEN EXAMINATION ELEMENTS
* Element 1 - Basic radio law and operating practice with which
every maritime radio operator should be familiar. To pass, an
examinee must correctly answer at least 18 out of 24 questions.
* Element 3 - General Radiotelephone. Electronic fundamentals and
techniques required to adjust, repair, and maintain radio
transmitters and receivers. The exam consists of questions from
the following categories: operating procedures, radio wave
propagation, radio practice, electrical principles, circuit
components, practical circuits, signals and emissions, and
antennas and feed lines. To pass, an examinee must correctly
answer at least 57 out of 76 questions.
* Element 5 - Radiotelegraph Operating Procedure. Radio operating
procedures and practices generally followed or required in
communicating by means of radiotelegraph stations. To pass, an
examinee must correctly answer at least 38 out of 50 questions.
* Element 6 - Advanced Radiotelegraph. Technical, legal, and
other matters applicable to the operation of all classes of
radiotelegraph stations. To pass, an examinee must correctly
answer at least 75 out of 100 questions.
* Element 7 - GMDSS Radio Operating Practices. GMDSS radio
operating procedures and practices sufficient to show detailed
practical knowledge of the operation of all GMDSS sub-systems and
equipment. The exam consists of questions from the following
categories: general information, narrow band direct printing,
INMARSAT, NAVTEX, digital selective calling, and survival craft.
To pass, an examinee must correctly answer at least 57 out of 76
questions.
* Element 8 - Ship Radar Techniques. Specialized theory and
practice applicable to the proper installation, servicing, and
maintenance of ship radar equipment in general use for marine
navigation purposes. To pass, an examinee must correctly answer
* Element 9 - GMDSS Radio Maintenance Practices and Procedures.
Requirements set forth in IMO assembly on Training for Radio
Personnel (GMDSS), Annex 5 and IMO Assembly on Radio Maintenance
Guidelines for the Global Maritime Distress and Safety System
related to Sea Areas A3 and A4. The exam consists of questions
from the following categories: radio system theory, amplifiers,
power sources, troubleshooting, digital theory, and GMDSS
equipment and regulations. To pass, an examinee must correctly
TELEGRAPHY EXAMINATION ELEMENTS
* Element 1 - 16 code groups per minute.
* Element 2 - 20 code groups per minute.
* Element 3 - 20 code groups per minute.
* Element 4 - 25 code groups per minute.
Telegraphy exams consist of both transmitting and receiving
tests. Examinees must copy by ear and send by hand plain text and
code groups in the inter- national Morse code using all the
letters of the alphabet, numerals 0-9, period, comma, question
mark, slant mark, and prosigns AR, BT, and SK. Examinees must
copy and send at the required speeds for one continuous minute
without making any errors. Each test lasts approximately five
minutes. The failing of any code test automatically terminates
the examination.
Code speeds are computed using five letters per word or code
group. Punctuation symbols and numbers count as two letters each.
Examinees may use their own typewriter to copy the 25 words-per-
minute receiving test, but must copy tests at lower speeds by
hand. Likewise, examinees may use their own semi-automatic key to
send the 25 word-per-minute sending test, but must send tests at
lower speeds using a hand key.
The Commission will grant credit for Telegraphy Elements 1 and 2
to applicants who hold an unexpired (or within the grace period)
FCC-issued Amateur Extra Class operator license.
TAKING A WRITTEN EXAMINATION
You must decide for yourself how to prepare for an examination.
The marine permit and basic radiotelegraph exams are relatively
simple. They may require only a few hours of study. The general
radiotelephone, GMDSS operator and maintainer, advanced
radiotelegraph, and radar examinations are more difficult and
require a knowledge of electronics. Electronics can be studied
through engineering and trade schools, correspondence courses,
military or employee training programs, or your own efforts.
The question pools, with answers, are available for downloading.
Each Element questions and associated figures) is completely
contained within a self extracting .ZIP file named element?.exe,
i.e., the Element 7 question pool is contained in a file called
element7.exe. The website for downloading:
http://www.fcc.gov/Bureaus/Wireless/Informal/
There are several commercially prepared study guides that cover
FCC examinations. Some are question and answer manuals based on
the official question pools. While most of these publications
include explanations which are de- signed to educate, a few
emphasize rote memorization of specific questions and answers.
Such "memory texts" may give you the impression that you can pass
the FCC examinations without learning the subject material. This
is not true. The FCC periodically changes exam questions to
maintain their integrity. You can maximize your chances of
achieving a passing score by mastering the subjects involved.
The FCC does not certify schools or review study materials.
Consequently, the FCC will not recommend any particular school or
publication. Adequate study materials are available in bookstores
and public libraries.
This e-mail contains an attachment that is in ".pdf" format. If you are unable to open this attachment, it is most likely because your computer doesn't have Adobe Reader, which is the program needed to open these types of files. You can install a free copy of Adobe Reader from the Adobe Web site at http://www.adobe.com/products/acrobat/readstep2.html.
Rep Number : TSR09
Mailout Attachment Name : COLEMS1.PDF (see attachment <COLEMS1.PDF>)
[email protected]
[email protected]
Examinations
questions.
the examination.
Rep Number : TSR09
OH
I do want to add that the pdf has something to do with the privatization of the certification testing and who is allowed to give such tests.
