Minimum receiver voltage under load
Old 10-03-2005, 09:47 PM
KamikaziRcPilot
Default Minimum receiver voltage under load
I'm using three different Castle Creation Phoenix speed controllers and I'm curious what the minimum acceptable voltage should be. I made an adapter that allow me to connect my Hangar 9 variable load voltmeter to an unused channel on a receiver. I can monitor the voltage under different conditions.
Using a Phoenix 35 ESC, I connected a Sombra Shadow 3 receiver, three Hitec HS-56 servos, and a Hitec HS-50 servo. Sitting idle, the receiver bus voltage is 4.90 volts. When I simultaneously exercise all four servos, the voltage dropped to near 4.00 volts. I tried this same process using a Phoenix 25 and a Phoenix 10 ESC and received similar results.
I also used a four cell NiCad receiver pack instead of using the power supplied by an ESC BEC (I feel like I'm back in the military again when I talk like that...), and the idle voltage was around 5.20 volts, and it dropped to about 4.85-4.90 volts under load.
I'm hoping the lower voltage from the ESC's are ok.
Any input?
Thanks....
Old 10-04-2005, 11:53 AM
themoster
Default RE: Minimum receiver voltage under load
Check the receiver specs...Many receiver use 4.4 volt regulators which me if you go below that erratic receiver operation is possible.
