Digital throttle on throttle?
Reply
Old 10-25-2005, 09:26 AM
David_Moen
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Digital throttle on throttle?
Hi there!
Is it a good idea to use a digital servo to control the throttle on a gas airplane? I bought a Hitec mini metal-gear digital for this purpose, but I've been reading that the higher level of vibration from a gas engine will cause a digital to burn out. Any thoughts?
David_Moen is offline
Old 10-25-2005, 09:28 AM
exeter_acres
exeter_acres's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Digital throttle on throttle?
No it isn't...they just can't handle the vibration... I use high speed standards
exeter_acres is offline
Old 10-25-2005, 08:11 PM
mglavin
My Feedback: (31)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have been using Hitec digitals on throttle for many years now never a problem all the way to 40% models. I don't suggest the metal geared versions. The Karbonites are my preference or nylon geared precision coreless servos.
Throttle requires precision repeatable results, in precision and 3D flight the throttle servo likely gets as much a work out if not more than other surfaces IMO.
mglavin is offline
Old 10-25-2005, 08:26 PM
WilsonFlyer
My Feedback: (13)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: exeter_acres
With all due respect, that's hogwash. The vast majority of us that fly giant scale (>25%) airplanes use almost exclusively digital servos as should anyone entrusting an aircraft of this type of investment.
WilsonFlyer is offline
Old 10-25-2005, 11:25 PM
David_Moen
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What I received for this purpose is a 5245MG, will that be OK?
Old 10-25-2005, 11:33 PM
mglavin
My Feedback: (31)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The metal gear servo will work fine but as with all metal geared servos the life expectancy is shortened some what due to the shock loads imposed by gassers. Using the servo for throttle is NOT a problem in fact this application is less imposing than buffeting surfaces IMO.
mglavin is offline
Old 10-25-2005, 11:37 PM
David_Moen
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Mike, I'll push ahead with this servo then. I've used your reccomendations for the remainder of the servos on this bird, 5945s on the ailerons and elevators and a 5955TG on the rudder. Even though it took me about 10 times longer than it normally would using my TX, I used a servo programmer to set everything up too.
Old 10-26-2005, 06:13 AM
exeter_acres
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sorry... I was just passing along what QuiQue and Andrew J. passed to me while I build.....
'but hey, what do they know
