Can I use a 9-channel transmitter with 4-channel receiver?
Reply
Old 10-29-2005, 04:59 AM
NebulaDDS
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Can I use a 9-channel transmitter with 4-channel receiver?
Using a 9-channel transmitter with a 4-channel receiver.
I've never tried this before, but thus far it doesn't seem to be working. Can it be done?
NebulaDDS is offline
Old 10-29-2005, 07:09 AM
exeter_acres
exeter_acres's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Can I use a 9-channel transmitter with 4-channel receiver?
assuming it has the same shift and it is the same frequency....
Yes...it can.. no problem
exeter_acres is offline
Old 10-29-2005, 08:38 AM
BarracudaHockey
BarracudaHockey's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yep. If the above is correct make sure the radio isn't set to PCM
It would help to know which radio and reciever your talking about.
BarracudaHockey is online now
Old 10-29-2005, 09:24 PM
ceandra
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
In most cases, yes. However, I did have an issue with an old Hitec micro (a 535, I think) with the Futaba 9C. The pulse train is too long for the old 5-channel window. It resetes and thinks the late pulse in the train is the synch pulse, and goes nuts. I understand the newer (555?) hitec is fine.
I have flown many 4 and 5 channel RX's, even the GWS pico 4ch, with my 9C. The old Hited/RCD is the only one I have run into problems with.
ceandra is offline
