PLL-synthesized
PLL-synthesized
Hello guys,
Does any one know how works the new PLL-synthesized RF module and R2000 ScanSelectâ„¢ 10-channel PCM receiver of JR?
Does it works with 72MHZ?
Can I choose any 72MHZ frequency?
Thanks for your answers,
Dor
Dor
RE: PLL-synthesized
If you get the 72MHz version from the USA, then you will have access to the 72MHz channels that are assigned to Aircraft in the US.
If you buy a 35MHz from Graupner in Europe, then you will get the GERMAN channels ( which are not the same as the UK 35MHz channels), and if you get the TS35J from the UK, then you will get all the authorised 35MHz channels for the UK.
How technical do you want to get on the Synth system ? I can go into it great detail or just skim over the fundamentals....
RE: PLL-synthesized
The 35J sold in the UK covers Ch 55 - Ch 90, which is 34.950 to 35.300 MHz inclusive.
So if you obtained a UK sourced TS35J the answer is yes. Unfortunately I cannot comment on other region sourced TS35J modules as I just do not know.
RE: PLL-synthesized
Not sure of the MC24 as I havent seen one of those. Best thing to do is to ring Gliders of Newark as they are the Graupner Distributor in the UK.
