Setting flaps on a 3 position switch on a 9cap
Can someone guide me about setting up flaps on a 3 pos switch on a 9cap? I did it once, but lost the memory on the radio and now I cant figure out how I did it.
RE: Setting flaps on a 3 position switch on a 9cap
Set the servo and linkage up so that with the switch in the center the flap is where you want it for 1/2 flaps. Set the full up and full down position by altering the end points.
If its dual flap servos, duplicate the throws on an aux channel and set up a mix with the flap channel as the master and the aux channel as slave or use a y harness.
