Hitec radio and throttle cut problem
Reply
Old 11-06-2005, 10:17 PM
talon29
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Hitec radio and throttle cut problem
Hello,
I am having problems reversing the throttle cut movement. I can adjust the +/- %, but am unable to reverse the direction when the throttle cut button is pushed. Anyone know how to reverse the throttle cut movement on a Hitec radio? Thanks.
Talon29
talon29 is offline
Old 11-07-2005, 01:22 PM
wisdom-seeker
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Hitec radio and throttle cut problem
When you press throttle cut, the throttle servo goes to the position you have set for throttle cut. Since the main stick will move you from 0 to 100%, a throttle cut setting of -20% should move the throttle servo to 20% lower than minimum throttle. Why would you want to reverse this? You do have to be sure that your engine carburetor will allow you to do this, and you should mechanically adjust the throttle linkage so that at minimum throttle, the engine is still running, but not at the throttle stop (if any) on the carb.
wisdom-seeker is offline
