H9 1/4 super cub which futaba servos
WA
Any recommendations on Futaba servos for Hanger 9 Super Cub. My first venture into large scale and want to get what will do the job.
My Feedback: (99)
GA
RE: H9 1/4 super cub which futaba servos
It is usually a good idea to go a little over on servos, however with a Cub you don't need to get to carried away. Second if your planning on upgrading at some point you can always get more then is needed. It is impossible to go overboard on servo speed and stength. Having said that a good choice if you want to go with Futaba would be one of the lower end coreless servos. Coreless are smoother and faster then non-coreless. I used the S9001 in 1/4 scale models before digitals were popular. They are also affordable at $29 each (Tower) and put out about 72 oz of torque with a 6V supply, it also has 2BB. This should be plenty for a Cub.
