Making a Futaba DSC Cable??
Hi, I have a Futaba buddy lead and i want to chop off one end and solder it to a servo extension to make a DSC lead.
Problem is I dont know what wires need soldering to which on the servo extension lead, if anyone can help it would be much apreciated!
Also can the DSC function only work on certain receivers?
Using a Futaba FF9, with square plug.
Many Thanks.
Many Thanks.
My Feedback: (12)
SC
RE: Making a Futaba DSC Cable??
ORIGINAL: jaycey
My Feedback: (16)
GA
Take a look at this link.
It should be able to help you address your problem
http://www.geistware.com/rcmodeling/articles/9c_dsc.htm
Pin 2 & 3 are the only two that you really need for signal transfer from TX to RX.
Hi,
First of all I'd like to confirm what is mentioned on the website of Geistware (he even used my drawing of the square connector...).
On the other hand I would like to mention that DSC is working exclusively with a receiver fitted with a DSC-connection. Plugging the DSC in a servo outlet will not work!
Olivier
Olivier
My Feedback: (16)
GA
Yep, olivier also has drawings of other plug types. I used his information to as an example to Futaba (hobby Services) to change the DSC cable that is shipped from Tower. They said no. The cable does not power up the TX unless you modify it. When powered up this way, it does not power up the RF section so I didn't see what the problem was.
Thanks for the diagram link
My Feedback: (16)
GA
The only receiver I know that has this is the Futaba R149DP, R309DPS and R319DPS.
ORIGINAL: jaycey
Hmm..what Futaba RX's have this? is it only the PCM ?
My Feedback: (12)
SC
ORIGINAL: Geistware
