Making a Futaba DSC Cable??
Reply
Old 11-09-2005, 03:24 PM
jaycey
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Making a Futaba DSC Cable??
Hi, I have a Futaba buddy lead and i want to chop off one end and solder it to a servo extension to make a DSC lead.
Problem is I dont know what wires need soldering to which on the servo extension lead, if anyone can help it would be much apreciated!
Also can the DSC function only work on certain receivers?
Using a Futaba FF9, with square plug.
Many Thanks.
jaycey is offline
Old 11-09-2005, 03:41 PM
Edge 540
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Making a Futaba DSC Cable??
My DSC works on all receiver's I've tried. I assume that all compatible plugs will work.
Edge  540 is offline
Old 11-09-2005, 03:53 PM
piper_chuck
My Feedback: (12)
piper_chuck's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: jaycey
I'm just a bit curious. The DSC cables cost about $9, but the buddy cords cost $12. Why not just buy the appropriate DSC cable and if you're not using the buddy cable, sell it.
piper_chuck is offline
Old 11-09-2005, 04:08 PM
jaycey
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hmm...Were a strange breed, us Londoners
Just having trouble tracking one down localy.
jaycey is offline
Old 11-10-2005, 08:27 AM
Geistware
My Feedback: (16)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Take a look at this link.
It should be able to help you address your problem
http://www.geistware.com/rcmodeling/articles/9c_dsc.htm
Pin 2 & 3 are the only two that you really need for signal transfer from TX to RX.
Geistware is offline
Old 11-10-2005, 10:13 AM
olivier
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi,
First of all I'd like to confirm what is mentioned on the website of Geistware (he even used my drawing of the square connector...).
On the other hand I would like to mention that DSC is working exclusively with a receiver fitted with a DSC-connection. Plugging the DSC in a servo outlet will not work!
Olivier
olivier is offline
Old 11-10-2005, 11:01 AM
Geistware
My Feedback: (16)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yep, olivier also has drawings of other plug types. I used his information to as an example to Futaba (hobby Services) to change the DSC cable that is shipped from Tower. They said no. The cable does not power up the TX unless you modify it. When powered up this way, it does not power up the RF section so I didn't see what the problem was.
Old 11-10-2005, 11:42 AM
jaycey
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hmm..what Futaba RX's have this? is it only the PCM ?
Thanks for the diagram link
jaycey is offline
Old 11-10-2005, 11:58 AM
Geistware
My Feedback: (16)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The only receiver I know that has this is the Futaba R149DP, R309DPS and R319DPS.
ORIGINAL: jaycey
Old 11-10-2005, 01:00 PM
piper_chuck
My Feedback: (12)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: Geistware
Futaba says the 113F and 113IP also work with DSC, but they have no special connection. The 3PJS and 9Z manuals show the DSC connection in the battery socket, and the battery connected to a spare channel. If all of the channels are full they suggest using a y adapter.
