Can I use a present servo in old system radio
Reply
Old 11-13-2005, 05:59 AM
Turk1
Turk1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Can I use a present servo in old system radio
Dear Guru s: I have an 1977 model OS Cougar 5 ch.Radio set ,4 normal Ch.and 1 for retract 27Mhz.AM.
It has 4 line servos and was usable until last week one of the 4 servo s got weird during rest in my trainer at home.I noticed by chance.
My question is: Can I use any contemprary 3 line servos in any way to make my set still usable?If so , how?
Turk1 is offline
Old 11-13-2005, 11:04 AM
dirtybird
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Can I use a present servo in old system radio
The forth wire in a four wire servo was for the center tap of the battery required in the old servos. It is not required for current servos. New servos should work if the pulse is of the right polarity. Some of the older systems pulse polarity opposite of current standard.
Make sure the +, - match, and the signal wire match on the connector and try it. Ignore the forth wire. You can't hurt it if the + and - wires are correct
dirtybird is offline
Old 11-13-2005, 11:45 AM
Turk1
Turk1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
DirtYbird,Thank you for your kind answer.This will be great if it work.
Turk1 is offline
Old 11-19-2005, 08:00 AM
Turk1
Turk1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
And I just could checked it and worked.Thank you again Dirtybird.My appreciation.
Turk1 is offline
